Error on PXI 4110 power supply card when running niDCPower Commit.vi
We moved a test system from one location to another, no changes in SW or HW. When running a test sequence now, we get the following error coming out of the niDCPower Commit.vi
niDCPower Commit.vi<ERR>The channel settings you have selected require an auxiliary power source, but NI-DCPower has already selected the internal power source.  Connect an auxiliary power source to the device.  To have NI-DCPower use this new power source, close the current session and open a new one, reset the device, or set the Power Source attribute/property.  For more information about power source management, refer to the NI-DCPower documentation.
We have restarted, shutting everything down, and also tried replacng the 4110 with a new one, new auxiliary power block, same error.
I'm stumped.
Message 1 of 1
(544 Views)
