Error "DAQmx Save scale.vi"
when I try to overwrite an existing scale with the VI "DAQmx save scale.vi" I get an Error -200356. The parameter "Overwrite Existing Scale?" is set to "true".
I've create the scalinig before with the condition "Allow Interactive Deletion?".
(3,169 Views)
Could you post a copy of your code?
Also, what version of NI-DAQ are you using?
Anders M
NI Denmark
(3,167 Views)
Hello M. Anders,
the code I've want to use you can find at:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=F1FCAA5EE87E4A64E0340003BA7CCD71
Download - 7_1_programmatic_saving.llb
Programmatic Saves of NI-DAQmx Tasks, Channels, and Scales Examples
I'm useing DAQmx 7.4 and LV7.1.
Thanks.
T. Nuding
(3,164 Views)
I have confirmed the error on my machine using the example.
I will see what I can find out and get back to you.
Regards
Anders M
(3,162 Views)
the Problem is solved:
Are you using the DAQmx Create Scale vi as well? It is actually not possible to create a scale with the same name as an existing scale. However, you can still modify and save an already existing scale. For an example of how to do this, check out the following link: http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=F38DB14830876FE6E0340003BA7CCD71&p_node=201209&p_source=External
Thanks a lot.
(3,157 Views)
Thats is definitly a usable workaround.
Anders
(3,150 Views)
