Error "Event Queue Overflowed" with the "Write file to Citadel Server"
I can import data from a file and I can see the data
in the historical database without troubling.
But I always have this error "Event Queue Overflowed", that don't perturb my data and my application (I have just this boring message).
I have tried many things :
- increasing the size of my input buffer (-> 1.000.000, no change) : I don't think so that it's important because I've tried with a value of 100 and anyway sometimes my application works with this small value of 100.
- increasing the File_location tag size (-> 260). No change.
- My write to Citadel.cfg is in the LabVIEW folder.
Can you help me ?
Thank you.
(2,798 Views)
What version of LabVIEW DSC are you using? if it is 6.1, have you applied fixes linked below.
http://digital.ni.com/softlib.nsf/websearch/513AA4A0BB60D10086256B48006D44B5?opendocument
I have seen a similar issue at the link below.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=5065000000080000008C640000&ECategory=LabVIEW.Datalogging+and+Supervisory+Control
Please let me know if you have read it through?
Best Regards,
Remzi A.
(2,798 Views)
My version of DSC is 6.1. I have applied fixes but it doesnt't work, you must use a data base with the current time with this module.
But after applied fixes, I have reinstalled LabVIEW and DSC and now it works, I don't have anymore this boring message.
Thank you for your help.
Thibaut.
(2,798 Views)
