09-20-2007 07:57 PM
09-22-2007 10:49 AM
Thanks to Kevin in tech support for investigating these errors. I did find after much work one of the VI's that is causing the "terminal hotpoint in wire..." error. It's a GET EXE STRINGS.VI in the custom OI. I have screen shots of it, but I don't know how to load them here... Anyway, it appears to happen on this particular VI because it has more than 20 connector pain terminals, but not all of the connections appear to be setup in the connector pane. However, this does not prevent the VI or the calling VI (TestStand - Execution Display) from running normally or even displaying a broken arrow (Why Not?). I changed the VI and removed the unused connections and the problem seems to be gone. I still need to find one more VI that is doing this. I also don't know why my Laptop is able to build the OI application OK w/o errors and other PC's always stop the application builder because of these errors.
Any other insight on this issue is greatly appreciated. Thanks,
David A. Gaud
