Error: "memory.cpp in line 876"
I have a VI in LAbview 6.0.2 that gives me a "memory.cpp" error when I try to run it. I tried deleting the "dir.mnu" as was suggested, but that did not resolve the issue. I also tried recompiling all the associated VI's, but that did not solve it either. What else can I try?
(2,816 Views)
> try?
About 95% of the time, the next step is to look for DLL nodes or CIN
nodes. The likely culprit is that a string or array is being handed to
the C code, which either overwrites memory, or leaves the array/string
data structure to an inconsistent state leading LV to overwrite memory.
Anyway, this is a very common cause.
If you eliminate that possibility, the remainder are usually some sort
of corruption saved in the VI, but normally those will not even load.
To simplif
y it before submitting it to support, please try executing
individual subVIs and see if the problem is limited to a particular VI
or a smaller set of VIs.
Greg McKaskle
(2,816 Views)
