Error: "not enough memory to complete this operation" when building EXE + LLB in LabVIEW 2009
Just upgraded to LabVIEW 2009 last week and can't build anymore.
I am building and EXE with support files in LLB.
PC Specs:
-P4 3GHz
  -4GB RAM
-Windows XP PRO SP2
- Windows is already enabled to use up to 3GB of virtual memory for applications.
- Performed a mass compile on all vi's.
Not sure what else to try and will appreciate any suggestions.
Tavi.
Message 1 of 9
(4,577 Views)
How big is your main VI that you are building into an executable?  Have you tried building a small test VI into an executable and see if you have the same problem?  Also this KB [broken link removed] might provide some insight.
Message 2 of 9
(4,554 Views)
This is a known issue in LabVIEW 2009. A CAR has already been filed to R&D for further investigation (CAR # 186602).
I am not sure if the steps listed in the KB linked above will help or not, but they may be worth trying.
Jarrod S.
Message 3 of 9
(4,549 Views)
Thanks Jarrod, I didn't even see that one...
Message 4 of 9
(4,546 Views)
David,
We already have our build setup this way, as you mentioned in the link to the KB [broken link removed]
thanks for the info guys,
Tavi.
Message 5 of 9
(4,513 Views)
This issue as well as a few others have been fixed in the LabVIEW 2009 f2 patch that was released today.  For more information, check out the following Knowledgebase for the list of resolved issues as well as download instructions.
Message 6 of 9
(4,491 Views)
Thanks David,
I just noticed the realease about 10 minutes ago,
I'll try it out and post the results.
Thanks again,
Tavi.
Message 7 of 9
(4,489 Views)
David,
I thought I should let you know,
The download link on this page is broken, doesn't seem to work.
Tavi.
Message 8 of 9
(4,486 Views)
Correct, I just checked and realized that the file hasn't been posted yet to the download page, but it will be available later today.  Sorry for the confusion.
Message 9 of 9
(4,476 Views)
