Error running USRP RIO multi device streaming Example
I'm starting with LabVIEW NXG 3.0.2 to operate a MIMO platform with multiple USRP RIOs. I wanted first to run the example provided by NI under the title:
USRP RIO 40 MHz BW Multi-Device Streaming. I ran the "Multi-Device Tx+Rx Streaming Time (Host).gvi", and I got the following error:
Error -1074100572 occurred at an unidentified location
Possible reason(s):
Failed to set the time on all the devices.
Details:
Timed out while waiting for CPTR. This may be due to misconfiguring CPTR on the FPGA or setting timeout less than the CPTR period.
I tried different Start trigger options, but with the same outcome.
Note that I have 4 Compatability warnings in the diagram that are saying similar things:
... wired type: Cluster with 8 elements, Terminal type: cluster with 8 elements
Any Idea guys?
Thank you In advance
(2,036 Views)
Dear ahmad_INSA,
Hello.
Do you solve this problem? I have met the similar problem.
(1,683 Views)
