Error running executable distribution build in 8.6
I wasI also having the same issue with an application that had multiple dynamically loaded VI's.  Forcing a compile on the top-level VI was not sufficient.  I also had to force compile ALL of the dynamically loaded VI's.  This appeared to have solved the issue.
Message 11 of 11
(516 Views)
