Error saving waveform from TDS 380 into spread sheet
I've been trying to save the waveform generated from TkTDS 3xx Read Waveform.vi to a spreadsheet or excel. I tried using "Write Waveforms to file.vi
However, this error was encountered, ""you have connected 2 terminals of different type. The type of the source is a cluster of 3 elements. The type of the sink is waveform double. Hence, I was wondering how do I save the cluster of 3 elements to a spread sheet?"
Attached is the vi i was working on.
Please help.
(3,701 Views)
You need to convert your existing cluster to a waveform data type. Use the Unbundle by Name on your cluster and wire up the outputs to a Build Waveform function. From the existing cluster, the array gets wired to the Y Array of Build Waveform, the t(0) goes to the t0, and the delta t goes to the dt.
(3,690 Views)
Accepted by topic author Wan81
Hi Wan81,
Yes, the method desribed by Dennis Knutson is right. You may refer to the picture below:
Clusters to Waveform
If you want to write the data in clusters, you may want to use Datalog Files. However, please consider to do so, if you want to read it back or manipulate  with ONLY LabVIEW. If you want to know more about Datalog FIles, you may refer to LabVIEW help as follow: Datalog Files Help
Please let me know if this solution is working or not for your application. Have a nice day!
Sincerely,
Krisna Wisnu
Application Engineer
NI ASEAN
Message Edited by Krisna Wisnu on 09-24-2008 08:16 PM
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
(3,678 Views)
Hey,
thanks a lot for the help. Going to try it now.
(3,670 Views)
how do I save waveform from both channels using the TDs380?
Ridwan
(3,544 Views)
Hi Ridwan,
First you would need to use two "Read Waveform.vi" to generate two channels (Channel 1 and Channel 2). You can duplicate the same VI and change the source input, one is Channel 1 and the second one is Channel 2 (Refer to main VI.PNG)
Second, you can use build array to append Channel 1 waveform and Channel 2 waveform (Refer to main VI.PNG).
Lastly, you need to change the "Write to Measurement File.vi" configuration X Value Column to one column per channel. (Refer to the Write To Measurement File Configuration.PNG)
Let me know if this works for your problem.
Sincerely,
Krisna Wisnu
(3,487 Views)
