Error setting output bit with PXI-6514 using an SCB-100
Hey all,
I've got a problem with my PXI-6514 DIO card. If I want to write an output bit with DAQmx Task, I can't measure 5V on the used SCB-100.
I'm using an PXIe-8108 controller with Labview RT connected to an PC running with Labview 2013.
I'm really new in this area, so completely lost and confused right now.
Cheers,
Lukas
(2,659 Views)
Hello luschm123,
what is the voltage you power up your DO and is external something connected?
If you try with a higher voltage for a test, did this voltage work?
best regards
Alexander
(2,614 Views)
