Error to open database
NI_Database_API.lvlib:DB Tools Open Connec (String).vi->Operator.vi<ERR>ADO Error: 0x800A0E7A
Exception occured in ADODB.Connection: Provider cannot be found. It may not be properly installed.Help Path is C:\WINDOWS\HELP\ADO270.CHM and context 1240655 in NI_Database_API.lvlib:DB Tools Open Connec (String).vi->Operator.vi
What I need to do? Help please.
(9,121 Views)
UDL.pngNeed More Info - Database type and how you are trying to connect.  I usually use a "udl" file.  You can test the connection by opening the file before using it in labview.
(9,107 Views)
Having a similar error come up. The VI was working with LV2012. Getting the error message below when opening it in LV 2017. Is there a 2017 library to update for this library?
(8,599 Views)
WyleCoyote,
The bottom of your error screenshot says the LV 2012 VI was saved with no block diagram, so you cannot convert it to a different version of LabVIEW.
(8,593 Views)
I resolved it by linking the VI to the latest addon library.
Michael
(8,590 Views)
