Error trying to insert 240 columns into a database
My VI reads a spreadsheet text file and attempts to write the data to a database. The database has 240 fields and the text file has 240 entries. When I run the app I get an error "Argument error; the number of columns does not equal the number of parameters." in DB Tools Insert Data.vi - seems to come from another vi called Parser.
Looking thru the code it indicates I need to use a cluster so all of the data will go to one record. Also I have tried variant data.
(3,080 Views)
The problem is in the Array to Cluster conversion -- the default size is 9 so it was only taking the first 9 elements of the array. Pop up on the Array to Cluster and select Cluster Size and change it to 241. That should work.
Also, I modified your VI a little for this. I also changed the array manipulation to use the least amount of memory and got rid of the extraneous sequence structure.
(3,080 Views)
Thanks Crystal,
That did indeed fix the error. Once I made that change I got an SQL error
Possible reason(s):
Exception occured in Microsoft OLE DB Provider for ODBC Drivers, [Microsoft][ODBC Microsoft Access Driver] Syntax error in INSERT INTO statement.. in Rec Create - Command.vi->Cmd Execute.vi->DB Tools Insert Data.vi->writeKPIV_(modified).vi
This was caused by spaces and equals signs in the field names.
Everything works great now. Thanks
(3,080 Views)
