Error using LABVIEW SIT SignalProbe In Simulink
Hi all,
I am New to Labview SIT. I have installed LV 8.6, SIT 5.0 and  Matlab 2007a. while using the SIT manual and trying to buid the 'sinewave.mdl, sinewave.vi' and run i get the following errors/problems.
1) I am unable to find a library named 'NISinks', 'NIXY Graph' .i can find only a library called 'NI Toolkit' with ' SIT out1, SIT in1 and SignalProbe'.  am i doing an installation error?
2)when i finish mapping as given in the manual and try to run i get errors in simulink
"  Error in 'Sinewave/SignalProbe' while executing C MEX S-function 'SignalProbe', (mdlUpdate), at time 0. MATLAB error message:."
3) After a while i get error from LV also.
4) I am atatching the screenshots of errors.
5) Is it necessary to use matlab RTW and create a DLL of the model even if you are not employing a real time hardware target. can i bypass the DLL process.
Please Help
Thank You in Advance
regards
Karthik
Message Edited by Foxbat on 05-04-2009 02:06 AM
Message 1 of 1
(3,373 Views)
