Error using "LDF Database Open.vi" for LDF 2.1 file
Hi there,
I use the USB-LIN for a simulation for LIN bus. We had the LDF file of version 2.0 before but now we get a new LDF file which is in version 2.1.
We used
LDF Starter Kit for LIN 1.0.1
to read the LDF file but it seems that the kit doesn't work any more with the LDF version 2.1.
It there a workaround for the LDF file with version 2.1.
Thx,
Wilbur
(3,835 Views)
The NI USB-LIN was created to work with the version 1.3 network standard. However, version 2.0 and 2.1 are backwards compatible, so the NI USB-LIN will work with these networks as well.
there is currently not a plan to update it for LIN 2.1.
Note: The new features introduced in version 2.0 and 2.1 network standards will not be natively supported with the NI USB-LIN.
LIN Version 1.3, 2.0, and 2.1 Comparison
Feature Supported by NI USB-LIN
 LIN 1.3
 Yes
 LIN 2.0
 Yes*
 Enhanced checksum  Yes
 Off the shelf slave node concept  Yes*
 NCF format  Yes*
 Diagnostics and slave node configuration  Yes*
 Byte arrays  Yes
LIN 2.1
 Yes*
New slave node configuration services  Yes*
Slave diagnostics class I-III  Yes*
Functional addressing  Yes*
Resolution table
 Yes*
(3,818 Views)
I do believe that the hardware still support the new protocoll. But my question was whether the LDF file in v2.1 can be accepted when I use the "LDF Database Open.vi".
(3,814 Views)
you can also try to install the new NI-CAN driver, which support the LIN-Bus.
NI-CAN 2.7.3:
http://joule.ni.com/nidu/cds/view/p/id/2646/lang/en
(3,805 Views)
