Error when adding Custom device menu In XML configuration for NI Veristand
I can't add shortcut menu in my custom device tree in NI Verisatnd  . When i make right click to add an input it show me the error at the location file is wrong or file was deleted  . Do you have any solution to resolve this ??
(2,727 Views)
Hello Kylexy94,
I found a document that explains why you can receive an error 7 with a Custom Device: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NBYSA2&l=fr-FR
The main causes are: VI renamed, wrong Build Specifications or XML file that does not match your settings.
Have a nice day!
Clement
(2,689 Views)
I have verfied that the possible raisons are not the problem  but it show me the following error 1162  "one or more tags are missed" .I thing the configuration LLB because i can't see my VI in the configuration tree. so what do you think about this ?
(2,684 Views)
