Error when building App but no error code displayed
When attempting to build an LabVIEW 8.01 App I receive an error message with no error code. The message says the error occured in the top level VI. No suggestions for possible cause.
(3,539 Views)
Can you post a screenshot of the error message (or lack thereof)?
Jarrod S.
(3,519 Views)
Attached to this post is a jpg of the App Builder Error
(3,509 Views)
Was there any further text available if you expanded the Details section of that error message? You might consider opening up CRAD GUI MAIN.vi and doing a force recompile of all the VIs to make sure there aren't any compilation errors present. You can force recompile a VI by holding down Ctrl and pressing the run arrow. You can force recompile a VI and all of its subVIs down the chain by holding down Ctrl+Shift and pressing the run arrow.
Does doing this break the run arrow?
Jarrod S.
(3,487 Views)
