Error when calling RGT tool kit
Hi,professionals,I am using RGT tool kit to read data from excel documents and joint the data together.Here below is the diagram.
When I click the 'run' button ,it usually run well ,with the screen spangles three times and a jointed big 2-dimension string array.But sometime it does not run well,saying 'Report Generation Toolkit: Microsoft Word or Excel did not open. Make sure Microsoft Word or Excel is installed.',and what was worse is that such phenomenon has no laws,absolutely random with a small  probability.I 'run'ed three times ,this error appeared once.
after I build a exe file,this thing turned bad ,the exe just get the first document's data, droped the last two documents' data(I have verified it by some other codes).I guess it is must  associated with the error phenomenon when in source code.
(3,826 Views)
I'm not sure, but try inserting a wait after the Close function. A "Stall Data Flow" VIM on the error wire from the last node to the side of the For loop (ignore the tunnel) should be fine.
If you don't have 2017 (and the Stall Data Flow VIM) then you can just use a Flat Sequence Structure and a Wait (ms) node and pass the error wire to the left side of the FSS. Try setting the wait to a second and see if it helps.
(3,806 Views)
Accepted by topic author alii001
Yes, trying to open a New Report after saving an old one can get you "stuck".  I encountered this, went nuts trying to figure it out, and noticed that the problem didn't occur when I had Highlight Execution turned on (which slows things down ...).
I went looking through some older code where I know I documented this (for myself), but, of course, can't find it.  I recall something like a half-second delay seemed to work, but you should do some testing, as it might depend on your system, version of Office, etc.
Bob Schor
(3,787 Views)
Thank you , after I insert a delay(ms) ,it seems work fine.
(3,773 Views)
