Error when converting binary string
Hi there,
In the attached screen shot, the VI works normally with a manually entered binary string, and converts it to ASCII text without any issue. However, when using the myDAQ to receive data from a transmitter, I get this issue. How can I fix this and get my ASCII text output correctly?
Christopher
Message 1 of 11
(4,972 Views)
Hi lad,
it really would help to make the display style indicator visible in ALL string controls, indicators and constants!
(Or to attach your VI with some useful data set to default…)
The error message is quite clear: what have you tried to solve the issue so far?
(I guess there is a wild mix of "binary string" and "ASCII string" in your VI. Display style really matters for strings…)
Message 2 of 11
(4,968 Views)
Hi there,
I've made a system which functions as a receiver connected to a myDAQ transmitter. It receives a repeating binary string of 0s and 1s, for example in the string 011111101100011000010110010011101001011011001110000001000111111011000110000101100100111010010110110011100000010001111110 we have the start bit which is always detected first, ~, which has a binary representation of 01111110. So after this, we have a match pattern function which reads after the start bit, so all that is fine. However, once we have the start bit, the conversion does not work. I have attached the VI image.
Message 3 of 11
(4,957 Views)
Hi lad,
why do you start a new thread instead of answering my questions and following the suggestions?
Still no display style indicators for all strings…
Message 4 of 11
(4,953 Views)
Oh okay sorry. I think I've narrowed down the issue to a small section in the VI, and I have no idea what the issue with this is. It's attached, and everytime I run it I get an error, but it should be receiving what it wants.
Message 5 of 11
(4,949 Views)
Hi lad,
would you please attach a downconverted version of your VI? (LV2017 would be fine.)
Message 6 of 11
(4,943 Views)
It is attached.
Message 7 of 11
(4,940 Views)
Hi lad,
just handle the error out of ScanFromString and you're fine…
Or simplify your code:
Message 8 of 11
(4,931 Views)
Thank you very much. But now, when I implement this in the program which reads 1000 samples of whatever word you input (in this case, it's chris) it doesn't read the word properly. The program you simplified and created works perfectly for a manually entered string of the correct length, but now, with my 1000 sample transmitter, I just end up getting garbage. The screenshot is attached, with the output I receive.
Message 9 of 11
(4,919 Views)
Hi lad,
for the next time: please make the "display style" indicator visible for ALL string controls, indicators and constants!
(Right-click the string -> visible items-> display style. For each of them!)
Where does that "Binary output" come from?
Message 10 of 11
(4,888 Views)
