Error when dynamically deploying library
The code below works when I deploy libraries containing most network shared variables. However, If one of the shared variables is bound to an I\O variable the code fails to deploy and returns the generic error -2147467259.
Is it possible to dynamically deploy I\O bound shared variables or is it only possible to do this Manually using the project tree?
(3,079 Views)
Can you post a screen shot of the error pop up?
Are you also deploying to your remote target?
What's the hardware acquiring/generating the data for the variables?
Wan L
http://www.ni.com/support
(3,008 Views)
