Error when install NI-DAQ 7.4
When I install NI-DAQ 7.4 I got this message : ''Developer Erorr :The following errors where found in your ini file :
1. Specified file not found: [MsiEngine] Win9xPath = suppfiles\instmsia.exe
2. Specified file not found: [MsiEngine] WinNTPath = suppfiles\instmsiw.exe
Exception code: E06D7363 ()
Fault address:  77E738B2 0001:000128B2 C:\WINDOWS\system32\kernel32.dll ''
Can anyone help me to install this software???....... please.
Note: I had Traditional NI-DAQ (Legacy) Version 6.9.2 but I uninstall it because it does not support the NI DAQ Assistant.
(3,066 Views)
Hello rammo,
Are you trying to install this from a cd or did you download the file from our website?
If it is from a cd, I would recommend copy the contents of your cd to your hard drive and then installing it from there.
If it is from our website, I would try to download it again, or try the installation on a nother computer.  It is possible that the file somehow became corrupted when you were trying to download it.
Just out of curiosity, are you installing NI-DAQ 7.4 Traditional?  If you want the newest version of NI-DAQmx, it is version 7.5!
Eric
DE For Life!
(3,039 Views)
Thank you E.Lee anyway.......
It was stupid mistake from me in extracting the file from zip file!!!
However, thank you for helping.
(3,033 Views)
