Error when programatically deploying shared variable library to cRIO
I'm having an issue deploying a shared variable library programatically... I am attempting to deploy the library to a cRIO from an exe that runs on a windows PC. Everything work fine on my development system (with full LabVIEW dev), but when my customer runs the exe (from their system with LabVIEW run-time only) the invoke node errors with code: -2147467259. I haven't been able to find any helpful information when I search that error code. Any help would be greatly appreciated! Do I need to install an additional run-time module on the customer's PC to allow for variable deployment?
I have verified the path to the library and the IP address of the cRIO.
(2,831 Views)
Hello Ryan85,
The error has a lot of different causes. Have you made sure the NI Variable Engine is running?
You can try the example on this document
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7k7SAC&l=en-US
or try this other approach depending on your LV Version
 How Do I Deploy Network Shared Variables from a Compiled Executable?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIDuCAO&l=en-US
Diego H
(2,787 Views)
