Error when programmatically adding item to LabVIEW project
I am trying to add a VI programmatically to a LabVIEW project using ActiveX property/invoke nodes:
22260iD54B2238687AF8CA
I get an error message (not an ordinary LabVIEW error) when the VI's name contains an underscore (which many of my VIs do...):
- when I try to add item.vi, everything is fine
- when I try to add item_.vi, the error dialog appears.
22262i3F2EFACF14F495AC
See attachment for an example application (LabVIEW 2010) demonstrating the problem.
Does anybody have an idea how I can avoid that problem without having to rename all my VIs?
(5,385 Views)
Accepted by topic author dlanger
Hello dlanger
you want to add a file please try this
22429i622B1C19B6B2AA02
Adding items is used for adding a folder to a project.
Pleas let me know if it works.
best regards
Alexander
(5,354 Views)
Super cool, it works! Thank you! 🙂
(5,346 Views)
