Error when running ocx-function
when i trty to run ocx-functions (which are working when called not using LV) then i get the attached error-popup.
Fatal internal error oleautomgr.cpp line 2832
What cani do to make it run?
Using LV 8.5
Thx for all help
(3,895 Views)
Hi OnlyOne,
Did you tried a mass compile of the folder where your files are localted?
See also http://digital.ni.com/public.nsf/allkb/AA97C01071D7CF678625695100582F40?OpenDocument
and this forum http://forums.ni.com/ni/board/message?board.id=170&message.id=269481&requireLogin=False with the linked knowledge base.
Regards
TomBaum
(3,868 Views)
Accepted by topic author OnlyOne
Its working now. The problem was inside of the ocx and /or OCX not correct registered.
But thanks for the info.
(3,866 Views)
Good to hear this.
Have a nice day.
TomBaum
(3,864 Views)
