Error when using the LINX Firmware wizard to generate the LINX Firmware
I've installed the LV 2025 community edition as well as the latest Arduino IDE.  When I try to generate the LINX firmware to be downloaded on my Arduino UNO, I get the following error:
"The Arduino base path is incorrect or the version of the installed Arduino IDE needs to be more recent"
I verified that the Arduino IDE is installed at the same place as shown in the Arduino Path but I still get the error.  Both LabVIEW and the Arduino IDE are installed in Program Files (x86).
I've run the example with my Arduino Uno and it works fine.  I would like to compile it and download it on the board.
Message 1 of 1
(375 Views)
