Error while Configuring DAQ Assistant for Voltage Measurement - LabVIEW 2022 Q3
I've been trying to work with the DAQ Assistant Graph in LabVIEW 2022 Q3 for a voltage measurement. I'm relatively new to LabVIEW. I'm trying to configure the DAQ Assistant for a basic voltage measurement using a single channel. I've selected the appropriate device and channel, but when I try to run the VI, I'm encountering an error that says "Error 2003: The requested property value is non-trivial to compute." can anyone please help me out Your assistance would be greatly appreciated!
(1,724 Views)
Hi Andrea,
I recommend to start the ExampleFinder and look for DAQmx example VIs.
There are examples for "basic voltage measurements". Please use them and tell us when they also show errors!
(1,714 Views)
Thanks for the suggestion, I appreciate your recommendation to use the ExampleFinder and explore the DAQmx example VIs for basic voltage measurements. I'll definitely give that a try and see how it goes. It's great to know that there are resources available to help troubleshoot and get started.
(1,647 Views)
