Error while creatiing executable - Error 1502
This issue was reported and captured in CAR 212136. It is reported as fixed in 2012 SP1.
George M
Message 61 of 65
(2,576 Views)
Hey Michael,
Thanks for sending over this test application. I have been able to test it on my 2012 SP1 install and am able to build successfully. I hope this helps!
Thanks again,
Kira T
Message 62 of 65
(2,564 Views)
Hi Ken, I get the same error when using Report Generation Toolkit and try to build my application. Enabled debugging, check all my 300 case structures (and no const wired to selectors), unchecked exclusions but nothing works.
You're right !!!!
A property node on Excel Set Color And Border on NI_EXCEL_lvclass was truly unlinked. Following your indication I've solved my problem!! Thanks a lot!!
Tiziano
Message 63 of 65
(2,499 Views)
Hi Tiziano,
Glad to hear my suggstion helped.
Ken M
Message 64 of 65
(2,483 Views)
I am facing the similar problem.Could you please let me know how is it related to case structure?\
chethan
Message 65 of 65
(2,255 Views)
