Error while install the LabVIEW after uninstallation
Hello
 i had to uninstall LabVIEW 2020 due to some reason. then i decided to install it again but encountered error during installation.
i tried many time to uninstall all package from control panel and its folder from C drive, then tried but same error.
can anyone help me on this.
asif
(918 Views)
If you uninstalled from the windows control panel instead of the NI package manager, you will run into problems (but you should also have gotten a warning!). Also, uninstalling should not require you to deal with folders and such. Can you explain exactly what you did?
Have you tried to download and use a new offline installer from here?
(869 Views)
I'm just waiting for Bob to drop by and say you'll probably have to reinstall your operating system because often that is the only solution.
Bill
CLD
(Mid-Level minion.)
(855 Views)
Accepted by topic author Asif138
i have to use microsoft install and uninsall software to install all sql and labview file from there. then i tried to install again and it was ok.
thanks everyone.
thanks
(825 Views)
