Error while saving VI - Insane Object at BDHP
Good Morning,
While saving Application VI, LabVIEW is giving warning as "Insane Object at BDHP+19CECC IN "Main.vi" : {graphics} (0X80) :Wire Segment (Wire)"
I am curious to debug this Warning. Would it impact in future development. Without harming to development of VI, I would like to clear it. If anybody has idea about this, it would be great help for me.
Also I am attaching Error as document file.
ii.
(3,514 Views)
You should be able to find the object that caused the error and remove it by following the procedure outlined here.
___________________
Try to take over the world!
(3,508 Views)
I faced a similar problem while saving a VI . I was suggested by NI helpdesk to copy the contents of the Block diagram and paste to a new VI. The problem was solved .
If you get a better solution please share.
Aditya
(3,496 Views)
Hi tst,
Thank you Very much!!!
Your link helped me solve Insane Warning.
Aditya, please have a look at link given by tst.
ii.
(3,480 Views)
