Error while trying to install NI-VISA driver on SUSE LINUX 11.1(The version of gcc in the path does not match the version of gcc used to compile the currently running kernel.)
hi i am trying to install NI-VISA driver on SUSE LINUX 11.1.
 the error message it shows is
          ******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to    *
* compile the currently running kernel.  This can cause unpredictable         *
* behavior in kernel drivers and should be fixed.                             *
* gcc version: Linux)                                                          *
* kernel compiled with: 4.3.2                                                 *
my kernel source version is
   linux-8nes:/home/admin # rpm -qi kernel-source
Name        : kernel-source                Relocations: /usr/src
Version     : 2.6.27.29                         Vendor: openSUSE
Release     : 0.1.1                         Build Date: Sun 16 Aug 2009 03:43:52 PM IST
Install Date: Sat 24 Oct 2009 02:13:12 AM IST      Build Host: rinck
Group       : Development/Sources           Source RPM: kernel-source-2.6.27.29-0.1.1.src.rpm
Size        : 309251954                        License: GPL v2 only
Signature   : RSA/8, Sun 16 Aug 2009 03:57:25 PM IST, Key ID b88b2fd43dbdc284
Packager    : http://bugs.opensuse.org
URL         : http://www.kernel.org/
Summary     : The Linux Kernel Sources
Description :
Linux kernel sources with many fixes and improvements.
Authors:
    Linus Torvalds <torvalds@osdl.org>
    see /usr/src/linux/CREDITS for more details.
Source Timestamp: 2009-08-15 17:53:59 +0200
GIT Revision: 8a413546901c407e96f7fba18574cceeb40452af
GIT Branch: SLE11_BRANCH
Distribution: openSUSE 11.1
i had also installed GCC 4.3.2.
it shows the error message as i had posted.
please kindly help me on this.
Thanks and regards,
P.karthick
(3,371 Views)
