Error: windows.h is a missing VI or C file. Commctrl.lib is a missing VI or C file. How to reslove this problem?
I have just installed the PDA module and every time I run it, I get the error: windows.h is a missing VI or C file, commctrl.lib is a missing VI or C file. How to reslove this problem?
Regards
Lars Chr.
(4,631 Views)
This issue was solved by re installing the software.
(4,609 Views)
I had the same issue and reinstalling did not solve the problem.. I manually tracked down the folders each missing file was in and then pasted them into the Labview folders that had the same file extension (.cpp, .lib, etc)
Always watch the log file that is generated when you try to build something.  There will be clues there to figure out why the error is happening
M
(4,198 Views)
Could you resolved the problem?. I have the same error
(4,028 Views)
