Error with Agilent 33120A and Signal Express
Hi all,
I am trying to use an Agilent 33120A in order to generate signals using LabVIEW Signal Express 2010.  I downloaded the required IVI drivers from the NI website.  However, when I try to run a simple step in LabVIEW Signal Express, I get the following error:
ivi_IviFgen Initialize With Options.vi<ERR>
Primary Error: (Hex 0xBFFA000F) Invalid parameter.
I cannot figure out where this error is coming from.  I notice that when I configure the IVI session name in the Configuration window, the resource descriptor and instrument driver fields are blank when I choose my hp33120a driver.  Any ideas on what may be the problem?  I am a a new user to LabVIEW so please pardon any ignorance on my part.  Thanks in advance for any suggestions.
-Tony
(2,637 Views)
You should post your question to the SignalExpress board. You aren't really using LabVIEW. You are using an application created with LabVIEW.
(2,634 Views)
