Error with Newton Raphson zero finder
Hi
I am trying to use the Newton Raphson zero solver to solve an equation, sin(x/2) / x = 0.125.
The start point is zero and the end point is 2*pi. A known solution for x is 4.9494.
I get the error -23001 and NaN as the answer. I am not sure why this problem exists?
Any advice is highly appreciated. A snip shot of my trial is attached.
Regards
Message 1 of 15
(3,557 Views)
@eddy1990 wrote:
.... A snip shot of my trial is attached.
No, that's just an image that we cannot inspect or debug. If you expect help, please attach your Vi instead
Di you try to graph your function to see if your assumptions are sound?.For example, you probably don't want a division by zero.
Message 2 of 15
(3,543 Views)
Try a start value of 1E-6 or so. At x=0 you have a divide by zero.
Message 3 of 15
(3,540 Views)
Hi
I tried but unfortunately that too gave me NaN.
Message 4 of 15
(3,535 Views)
Hi
I tried plotting the values and I get a zero crossing. Attaching the VI for reference.
Message 5 of 15
(3,534 Views)
Make sure "sin" is lowercase in the formula. (You are using "Sin")
Message 6 of 15
(3,523 Views)
Hi
I tried the lower case as well, but the result is still NaN.
Message 7 of 15
(3,520 Views)
Works just fine here....
Message 8 of 15
(3,508 Views)
Hi
Thanks for your effort. Can it be because I am using 2019 version of LabView?
I tried the VI you send me and it gives NaN result using LabView 2019.
Message 9 of 15
(3,499 Views)
Hi
Attaching the 2019 version, with which I tried.
Message 10 of 15
(3,489 Views)
