Error with Shift Register
Hi.
I have a problem with my VI again.
I manage to solve the previous problem.
However, another problem occured.
Please refer to my VI as attachment.
Firdaus
(3,106 Views)
Accepted by topic author Fird
The output of your "equals" operation is a boolean array, not a boolean.  You can use the "And Array Elements" function to test that all elements are true and wire that output to the case structure.  Was this the problem you are referring to?
Message Edited by jmcbee on 02-27-2009 08:02 AM
(3,100 Views)
