Error with data sent with VISA communication
But the VI you posted TI_New.vi is using 0xA not 0xD
Omar
Message 31 of 46
(1,230 Views)
Can you confirm that you are still getting an error on the write. Until Omar_Ii pointed this out, I hadn't noticed this. The termination character is irrelevant for a write and that error.
Message 32 of 46
(1,218 Views)
Here is what I came up with from combining both of your threads.  The first major thing, you need to allow a timeout.  I recommend just leaving the default (10 seconds).  Secondly, you need to disable the termination character since you are dealing with binary data.  Third, you need to close your serial port when you are done with it.
Message 33 of 46
(1,214 Views)
I am replacing the termination character 'D' instead of 'A' in VISA Configure SErial Port.vi.
Message 34 of 46
(1,211 Views)
Hi crossrulz,
I jsut tried the one you posted(updated).Even if I use this the "Data" is getting updated after around 20 seconds.
Can you help me out in geting and plotting the number of samples in 1 second.
Message 35 of 46
(1,208 Views)
@PatanGova wrote:
Hi crossrulz,
How sure are you that you are only recieving data every 20 seconds vs getting the data and the data just hasn't changed?  You might also want to put an indicator on the iteration counter (the i in the loop) to see how often the loop is iterating.
Message 36 of 46
(1,202 Views)
I added some timeing functions to crossrulz.
Tell us the results for Reply Time and Max Reply Time
Plus are there any Errors and does the read buffer string look like what you expect?
Omar
Message 37 of 46
(1,200 Views)
Can you please provide me a Labview2011 version vi.
Message 38 of 46
(1,196 Views)
2011
Omar
Message 39 of 46
(1,184 Views)
Hi Omar,
I observed these with the vi you posted
Replytime  MaxReplytime LoopCount
4006              4006                    1
4018              4022                    2
4011              4022                   3
4016              4022                   4
4050              4050                   5
4144              4144                   6
And the Readbuffer values are being updated(changing) after 30seconds(around).
Message 40 of 46
(1,180 Views)
