Error with the format of a Numeric input
When inputting an number into a numeric number, I put two dots instead
of one and the numeric input discarded my number and put zero instead.
How can I setup the numeric input that when it checks the number for
correct input and removes the extra dot?
(2,556 Views)
There is no way of specifying a numeric control should ignore extra
decimal points. The closest you could come is to use a string control
and perform the parsing yourself, which would have many drawbacks. I
hope this is helpful.
Shawn Walpole
(2,556 Views)
Thanks, I think trying to do the parsing myself would be a waste of
time.
Thanks again
(2,556 Views)
