Error with the reset method, code error 61167 - Labview FPGA
Hello
I'm trying to update a project made by someone else some years ago, and the first error I get, when I try to simulate it, is on the reset method at the start of the program, here is the schematic :
 The program would'nt work and to know what was wrong with it I got the program to show the error with the following module :
And I get this error message :
and when I look at it with an error handler, it says the code error is 61167
Any help on where it could come from and/or how to correct it would be appreciated.
Adèle DUCOIN
(2,443 Views)
The error code, when checked in LabVIEW (note, I think you meant -61167), is as follows:
Error -61167 occurred at an unidentified location
Possible reason(s):
LabVIEW FPGA: This function is not supported when the FPGA target is configured for Simulation.
I guess you can't reset during simulation?
(2,416 Views)
