Error
Hi I'm trying to setup an email VI that will can just send a simple text email and I keep getting Error 363514: "An error occurred while receiving data from the network" I attached a screenshot and the VI. Any help would be much appreciated!
Message 1 of 8
(5,515 Views)
Accepted by topic author wholefeed
Try 587 for the port and put a true on Use TLS.    I use a g-mail account and that works for me.
Make sure your login user name is   YourName@gmail.com   And that the password is correct.
You may want to try to log into g-mail from the PC you are running this VI on.  Also, in your g-mail account settings, there is an option under Security for "allow less secure apps" or something like that.
The reason to log in is that g-mail seems to not accept e-mails from a source that is doesn't recognize.  You may have to do some 2-factor authentication or something to let g-mail know your are sending from a valid device and you aren't a rogue agent.
Message 2 of 8
(5,497 Views)
Hey that's all it took lol. Thanks so much.
Message 3 of 8
(5,483 Views)
Glad to hear you got it working.
Out of curiosity, which of those things I listed was the key for you?
Message 4 of 8
(5,480 Views)
Hey!
can you explain here, How did you rectified Error 363514 problem in SMTP mail
Message 5 of 8
(5,312 Views)
I'm getting same problem in Labview
Message 6 of 8
(5,309 Views)
Oh my bad. I didn't even see this. But all i missed was a true constant on the function.
Message 7 of 8
(5,285 Views)
RavensFan pointed it out. I used the port 587 and put a true constant on the "Open Handle" VI
Message 8 of 8
(5,282 Views)
