08-09-2023 03:38 AM
I am getting Error during Enqueue , when I am running this below Sub VI this below error is coming.
I would be grateful if somebody help me related to this topic.
08-09-2023 04:06 AM
Hi Poojaavi,
Make sure the queue reference is valid…
08-09-2023 08:22 AM
Most likely causes here:
1. You did not initialize the queue.
2. You closed/destroyed the queue before this call.
3. Your FGV has a bug where the queue reference is not wired through a case and the tunnel is set to "Use Default If Unwired". You should only have a tunnel set to that in very limited cases because of this type of situation.
08-09-2023 10:19 AM
4. You call the FGV that creates the queue in another top level hierarchy than this VI and that other top level hierarchy has since gone idle.
Reason: All LabVIEW refnums are auto collected (closed) the moment the top level VI in whose hierarchy they were created goes idle.
