Error10022 occured at Digital Buffer Write
Can someone take a look at the code and see what I am doing wrong? I'm using a 6533 card.
(2,528 Views)
It looks like you are taking the length of one array whose length is not the same as the array that you are trying to write. Try changing the length of the number of scans to be the length of the array that you are writing.
If that doesn�t work take a look at the following shipping example.
Help>>Find Examples
Browse>>Browse According To>>Task
Hardware Input and Output>>Traditional DAQ>>Digital Input and Output>>653x>>Buffered Pattern Output.vi
Let me know if you have the same error here or not.
Justin T.
(2,528 Views)
