07-28-2005 03:32 AM
07-28-2005 06:59 AM - edited 07-28-2005 06:59 AM
Basically, the only way to make a LabVIEW 7.1 vi run under 7.0 is to load it into the 7.1 development system and then do a "Save with options", "Save for previous". I'm not sure if this works for the toolkit you mention as I don't know if it contains any items that are version specific (there are things in the 7.x version of LabVIEW that won't translate backwards to 6.x for instance). Is the toolkit a recent purchase, as National Instruments ships the toolkits that are compatible with the current version of LabVIEW, which is 7.1 / 7.1.1
P.M.
Message Edited by LV_Pro on 07-28-2005 07:59 AM
07-28-2005 07:06 AM
Hi thanks for your help... the toolkit is compatible with Labview 7.0 or later...I can't open the VI because I don't have Labview 7.1 I have only Labview 7.0 is there another possibility to open it with 7.0?
Labprog
07-28-2005 01:30 PM
