Errors in running the vision application
I am working on vision acquisition using the usb camera,
My vi runs successfully on the PC with labview installed with all toolkits.
I created the application of my vi.
And run it on a different computer which has latest ni run time engine installed.
It gives errors of missing sub vis.
I could not find the solution of this issue, kindly inform me how can i solve the issue.
I have attached the error log.
Thanks alot
Message 1 of 11
(3,349 Views)
You must have created installer  to use the Exe in other PC which doesn't have LabVIEW. You can create the installer the same way you created exe by including LV runtime engine and the Vision tools.
Message 2 of 11
(3,344 Views)
Are you sure you have installed the vision development modue?
Message 3 of 11
(3,341 Views)
opps sorry you are having this iisue with exe. You require vision runtime apart from labVIEw runtime
Message 4 of 11
(3,339 Views)
@muks
On the other pc their isnt any sofware execpt the labview runtime engine.
Message 5 of 11
(3,338 Views)
Then create an installer along with the Vision RunTime engine from the developement PC and install in the other PC, then everything will be alright.
Message 6 of 11
(3,327 Views)
That is the issue then. You need to have vision run time too.
Message 7 of 11
(3,324 Views)
What i have concluded is that
1- I need to create a installer instead of an Application.
2- I need a vision run time engine along with labview run time engine to run the application.
Am i right.
Message 8 of 11
(3,320 Views)
Also the link to this vision run time engine is broken.
Can you pls give me an unbroken link to download its evaluation version
http://digital.ni.com/demo.nsf/websearch/01414632a3582a71862573060079b8e1?opendocument
Regards
Message 9 of 11
(3,316 Views)
Yes. Definetly. Smiley Happy
Message 10 of 11
(3,315 Views)
