Errror 1305 When installing Lab View 7
When installing labView 7.0 receive the following:
Error 1305.Error reading file: C:\WINNT\system32\ninetbrw.ocx. Verify that the file exists and that you can access it.
My problem is that the installer places this file out there and does not seem to be able to access it.
(2,653 Views)
There are two possibilities:
1. There is a problem with the CD - Try copying the contents to your hard disk drive and try the install from that location.
2. The installer service does not have adequate permission to access your System32 folder - This can happen if you have NTFS on your drive and the "System" account does not have Full Access to this folder.
If item two doesnt make sense, please repost and I will try to walk through in more detail.
Naren
(2,653 Views)
