Eseguire una store procedure da labview
Ciao,
qualcuno sa dirmi come si fa ad eseguire all'interno del codice labview una store procedure che interroga un database di sql server?
Grazie,
Giuseppe
(3,191 Views)
I'm sorry.. this isn't the italian forum..
but the question is:
how can I execute a store procedure of a sql server database with labview?
Giuseppe
(3,185 Views)
Hi!
you can use the "DB Tools Create Parameterized Query VI" provided with the Labview Database Connectivity Toolkit.
I've found quite tricky to use stored procedures with output parameters.
Marco
(3,181 Views)
Accepted by topic author sepp974
(3,161 Views)
Hi Giuseppe,
did it work even for stored procedures wirh output parameters?
Marco
(3,159 Views)
Yes, this exemple shows how to read an output of a stored procedure
(3,156 Views)
