EtharCAT userdefine variable issues in RTexe
I have cRIO 9045 and two 9145 EtherCAT cassis. I have communicate the data EtherCAT to RT code through user define variable. Project in LabVIEW2019 version.
Issue details :
When i run the RTexe the data communication to EtherCAT is failed.
I debug through  "Advance"> "Enable debuging"  in RTexe then i found its showing user define variable is "unavailable or delected".(See in the attached screenshot)
Note : The communication between Host GUI to RTexe is OK . Rtexe running ok, only issue in UDV.
Trying way :
Check the driver of RTexe in cRIO.NI Industrial EtherCAT driver availble. I have attached screenshot.
I have tried install V20.0.0 and v19.0.0 driver in cRIO and no resolution.
Coluld anyone please guide me, Where is the issue?
(1,545 Views)
Can you send the screenshot part/tab of the error ?
(1,435 Views)
