EtherCAT PDO mapping blank
I'm using a cRIO 9054 as the EtherCAT master. I have one slave added, and successfully imported the ESI file. However nothing is showing up under the slave. Did I miss something? I was successful with PDO mapping for the same slave device using a cRIO 9057 fwiw.
Message 1 of 1
(869 Views)
