Ethernet IP & events
I am communicating with a PLC using ethernet IP. Currently I am using poling within the time out event to read the PLC tags but would like to set up an event to respond to a change in a tag value automatically. Does anyone know how to do this?
(3,616 Views)
Accepted by topic author SimonAldred
Unfortunately, you have to keep polling the PLC since the library does not do that for you.  What I recommend is to use another loop for the Ethernet/IP communications and send a User Event when a value changes to let your main loop know.
(3,579 Views)
Thanks for the advice. I'll give a go.
(3,571 Views)
