Ethernet to RS 232
Hallo all,
did anyone try to connect to a serial device via a ethernet2serial
adapter??
We are trying to do this, using the ADAM 4571.
Also does anyone have expirience with Bluetooth (as serial connection)??
Thx for helping
chris
Message 1 of 8
(3,794 Views)
No experience with bluetooth, but I have used enet to serial converters before. Specifically, we used the one made by Black Box. The thing I liked about it was that the interface for talking to it was a telnet connection. The main thing to be on the look-out for is that the internet toolkit is rather spotty in places in terms of error handling. You can send a message and think all is well with the world but it didn't go through due to a low-level error that didn't get propagated.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(3,794 Views)
I am working on creating a serial interface between bluetooth and a single board computer using Labview 6i. Let me know if you need more information on that.
Message 3 of 8
(3,794 Views)
What device do you use between the RS232 and the bluetooth? Just curious:)
Message 4 of 8
(3,794 Views)
It is a Microchip microcontroller, PIC 16F 872. HOpe that helps.
Message 5 of 8
(3,794 Views)
kmoorthy76107:
I am interesting in bi-directional communcation between Bluetooth and computer via a high-speed (460 kbaud) serial iterface. Would you be available to talk to me about this (pagarri@ilstu.edu)?
Message 6 of 8
(3,794 Views)
Sure. Email me. Make sure you have the virtual channels when configuring the BT module using LabView.
Message 7 of 8
(3,794 Views)
Hi people, please, I'm using ENET 232/2 device also, I will receive a serial signal, and I have to read it via ethernet in labview
I have to use VISA serial for to do this or is required a different block on labview?
Message 8 of 8
(3,079 Views)
