EthernetIP read tag to double
Hi everyone,
I'm using E/IP read tag blocks (type REAL) in my Labview 2014 vi.  I'm attempting to take the data from these and bundle them into a cluster, where the inputs for them are doubles.  So far, I haven't found a conversion that satisfies Labview.
Any thoughts and advice would be greatly appreciated.
Thank you,
 Nick
(3,252 Views)
I'm not understanding your issue.  You can't figure out how to use Bundle or Bundle By Name to create a cluster?
(3,235 Views)
I've got a bundle block with some double slots to cram data in.  The data type coming from my EthernetIP tag read is a real type.
Thinking about it some more, I believe I've hit this kind of issue.  I'm forgetting that the data that comes out of a read tag isn't just a variable.  It's an array consisting of an index and the data I want.  That's probably the issue.  Take a look at the bottom middle of this block diagram.
(3,215 Views)
Yep, you are reading an array of values.  And array cannot go directly into a scaler.  You probably just need to use Index Array since you are only reading a single sample.
(3,208 Views)
