Ethertypes
Hi.
I need to communicate LabVIEW with a device using EtherCAT protocols.
So, I have change the Ethertype in UDP Data Communications, but I don't found in UDP function's, How can I do this.
Someone have a similar problem?
Can I help me?
Thanks.
(3,380 Views)
(3,347 Views)
If you want to brushup ethercat
Message Edited by muks on 09-21-2009 09:17 PM
(3,344 Views)
Hi Muks..
Thanks for help me.
I'm not using NI EtherCAT slaves (cRIO-9074) and not exist driver for my device.
So, I'm try to make a EtherCAT protocol using UDP. But, I've set the Ethertype 0x88A4 (Beckhoff EtherCAT) and the LabVIEW don't provide this.
Do you know TwinCAT (Beckhoff's PLC Software)? Do you know how can I access the TwinCAT by LabVIEW (Dll or Ocx)?
If I can access by TwinCAT I haven't to do the EtherCAT protocol.
Thanks.
(3,313 Views)
