Eularian Video Magnification
I am trying to implement the Eulerian Video Magnification (EVM) algorithm in LabVIEW, but I am having some difficulty. I have followed the instructions in the EVM documentation and tried to adapt the examples provided, but I am still having trouble getting the code to work correctly.
I was wondering if anyone in the community has experience with implementing EVM in LabVIEW and would be willing to share some advice or resources that could help me. I would really appreciate any help or guidance that you could provide.
Thank you in advance for your help.
Younes
(1,603 Views)
Hi younes,
The typical way this forum works is: explain the trouble you have, list the errors you encounter and attach your current code!
(1,570 Views)
In addition to what has been said, provide a link to a description of the algorithm (example) so we don't need to guess. What "documentation" did you follow?
Since you posted in the LabVIEW forum, it is also not entirely clear what tools you are trying to use. Just plain LabVIEW and math having the video as 3D RGB array? Any of the imaging and machine vision toolkits?
Once you attach your attempt (VIs, not pictures) we can probably point you in the right direction.
(1,560 Views)
